Transferring User Data from Nokia to Sony Ericsson
2 replies · 6,789 views · Started 21 October 2009
My boss has a much loved and well used Nokia N95 8gb which is being replaced tomorrow by a Sony Ericsson Satio, (assuming that Vodafone remember to ship it out).
Is there an easy way to transfer all the user data ie. Contacts, Messages and Calender from one to the other?
Thanks in advance
Rob
This reply is not because I have the experience , Hope it works ... but since the Satio is a Symbian S60 v 5 Phone , I think compatibility shouldn't be a big issue ...
1) Bluetooth : Nokia N95 has : Instruments > Data Transfer . An application like that should be on the Satio . Just connect and do your selections .
2) PC : Nokia PC Suite installed on PC , or the equivalent from Sony Ericsson . Connect to USB and do the datatransfers . Nokia and SE Cables are different though . Select PC Suite Mode .
3) When the N95 is synced with Outlook , use this .
Hope you get the transfer done smoothly .
😊 Regards jApi NL
