Contacts
8 replies · 1,845 views · Started 12 March 2003
Dear Pros,
Could I store 4000+ contacts on the P800?
If so, what is the storage request?
Thx
[quote="Zak248313"]
😮[/quote]
Currently using Nokia 7650, with 3500 contacts, but dancing on the edge of the 4MB limit...
Zak, the 4000+ contacts might be sound interesting for a normal phone user, but not for a PDA. I am using mobile phone for communication (business mainly), syncing with the corporate office PC network.
Yes how many contacts is the limit for the P800?Would this depend on memory size or would it be possible to store more contacts on the Memstick?
How can I know how many contacts are in the phone???
I tried all day, but I was not able to sync all the 3,500 contacts from my Outlook XP :bad-words:
The sync stops with "DXP SyncML Module" error, then says it is finished.
NO!!! It is not finished! :cry:
sorry did not get this.
I would also like to buy a P800... I would like to add around 2000 contacts.
The announcements of the P800 say one can go to UP TO 1000 contacts...
or can I have more when I use a memory stick???
[quote="JTX"]How can I know how many contacts are in the phone???
I tried all day, but I was not able to sync all the 3,500 contacts from my Outlook XP :bad-words:[/quote]
As an experiment, why dont you try to get rid or backup your other files on the P800 or move them to the memstick(pics,wavs,other sounds, games etc..) at least clear up around 8-10mb of space and sync again. Please post if its succesful.
