ovi only restores some of my contacts
5 replies · 4,243 views · Started 21 October 2009
just formatted my phone, and restored from Ovi. calandar restored fine, but about 50 contacts are missing from my phone. Can any one help?
cricfancy wrote:Hi,
Have you restored from OVI.com or OVI suite ?
hiya, sorry it was from OVI.com
i can see the contacts that are missing online, but it doesn't restore them.
There doesn't seem to be any logical reason for which ones it does or doesn't restore.
This isn't the first time I read this. It's a good thing I'm not using it. Which version were you using? If you've done a backup before just restore using one of the older backups. If you've deleted the old backup, then you should be able to recover somehow. If this was your first backup, then you're fucked.
r-486 wrote:This isn't the first time I read this. It's a good thing I'm not using it. Which version were you using? If you've done a backup before just restore using one of the older backups. If you've deleted the old backup, then you should be able to recover somehow. If this was your first backup, then you're fucked.
No. i have it all backed up on pc, but thought it would be nice to do it over the air thats all
