Well, up until today my N97 was just annoying. Now after a trip to the gym this evening I removed my headphones and nothing - the headset icon stayed on.
Have tried powering off and on, inserting the headphones again and starting the phone up with the headphones in. Tried a battery pull... No luck. :frown:
Has anyone else had this and managed to resolve it without a trip to a service centre? I really don't want to have to make a trip to a service centre as this phone will have required more 'servicing' than my current car.
celios wrote:Well, up until today my N97 was just annoying. Now after a trip to the gym this evening I removed my headphones and nothing - the headset icon stayed on.Have tried powering off and on, inserting the headphones again and starting the phone up with the headphones in. Tried a battery pull... No luck. :frown:
try a factory reset from in settings, do a backup first tho, if that dont worrk try a hard reset.
My old HTC Prophet had a problem similar to this, turned out to be a pin in the headphone socket that was poorly made and got stuck down. Made it almost unusable :/
hopefully it's a software thing and not another hardware fault!
Thanks for the info guys (or gals!)
This is a hardware problem but I managed to sort it using a needle. 😮
The headphone socket on my N97 has 3 gold contacts - two near the bottom of the socket on one side and one nearer the top on another side. I noticed the contact near the top used to stick out quite a bit when the socket was empty but was now less visible and guessed this must be the contact used to check for the existence of headphones. Managed to use a loupe and a needle to move the contact out a little where it had become stuck and immediately the headset icon disappeared from the display.
Tested it with my headphones and it seems to be working again, the contact must have got stuck in the 'on' position. It'll probably happen again, but hopefully I will be offloading the N97 in the next month or so and should be able to get shot before it happens again.
Very good solution.
But a toothpick can bring also the solution!
Tutch with a metal thing !!!!!
