Hi there....
is there any software available in the space which can enable me to set a full screen wall paper....
i know there are s/w which can make full themes and then enable using a wallpaper of choice.... but i just need the wallpaper only.....
also is it possible to keep the desktop(screen) fully clear of things like signal, battery etc.....
thanks in advance
Full Screen Wallpaper for Nokia N85
Open a nice picture from your storage > Options > Use Picture > As Background : Wallpaper for Homescreen/Desk is set now
When you like a wallpaper in all the User Interfaces , then you need a theme that provides it .
Tip : play with Settings and Options a lot , to find all kind of Personalizings .
😊 Regards jApi NL
