Hi All.
Should be getting my (white) Three N97 on Tuesday.
I intend to debrand it the same day!
I assume this is the code i need
0570817: RM-505_EMEA_EURO_QW1 Black?
I have read and reread the page linked below
http://nokia.nigelcoldwell.co.uk/firmware.htm
Now i know i need to shutdown and exit Nokia pcsuite, but when i connect the phone, i assume it will ask me what mode to connect in, is it "usb mode" ?
And one other question, i don't know what version FW it will be running when i get it, but does it matter, can i just plough straight into it?
ps running Vista
Oh dear... not off to a good start here I'm afraid.
You mention that you are getting a "white" N97 and then proceed to give the BLACK Euro code.
You might be better off with this code:-
0576350: RM-505_EMEA_EURO_QW1 White
I assume you mean connecting to NSS. That is done in virtual USB mode.
To find what firmware your phone comes with just type *#0000# on the dial screen.
You will need to use the Nokia Software Updater to install the unbranded firmware.
Hi, cheers for the reply, i used the most commonly posted product code, so assume this would be the safest one.
I was sure that i had read that the colour wasn't relevant.
Thanks V Much
So, does it make any difference (with regard to debranding) what firmware the phone arrives with?
Not as far as I'm aware. So, come on people who've done it; should I de-brand?
I did my N95 (which I'm seriously considering going back to) with NSS, which was unbelievably easy. Is it the same process with the new NSS or do I have to learn to use JAF?
Learn to use JAF - I did and it only takes about a minute.
N97 Fanatics have a good article:
http://www.n97fanatics.com/complete-guide-to-unbranding-your-nokia-n97/
I'm on Three also and would highly recommend it. I had to wait a month for the first update to be released by them and I'm not doing that again!
Cheers jonathan, much appreciated. I'll give that a go tomorrow evening.......wish me luck!
Surely the method linked to in my first post is by far the easiest?
riverboat wrote:Surely the method linked to in my first post is by far the easiest?
I think so too Riverboat 😊
angiepea wrote:I think so too Riverboat 😊
Is that the method you used?
I have been folowing all the postings in the thread about V2!
yes i've debranded 2 N97s with that method, and although someone was "holding my hand" so to speak the actual process in the end was really siimple 😊
riverboat wrote:Hi, cheers for the reply, i used the most commonly posted product code, so assume this would be the safest one.
I was sure that i had read that the colour wasn't relevant.Thanks V Much
I own a black N97, roughly 75% of N97 owners have black which is why the code is widely quoted, and so therefore cannot say definitively what the differences are between the black and white firmwares although I am given to understand that there are subtle changes, possibly theme related. I don't see Nokia going to all the trouble of releasing colour coded firmware without a reason. Either way, it seems that both will work on each model.
As for the firmware the phone comes with, and it's affect on debranding, you should stick with NAM firmware if that's what the phone comes with, and Euro if it's a European model as there are differences.
[email protected] wrote:I own a black N97, roughly 75% of N97 owners have black which is why the code is widely quoted, and so therefore cannot say definitively what the differences are between the black and white firmwares although I am given to understand that there are subtle changes, possibly theme related. I don't see Nokia going to all the trouble of releasing colour coded firmware without a reason. Either way, it seems that both will work on each model.As for the firmware the phone comes with, and it's affect on debranding, you should stick with NAM firmware if that's what the phone comes with, and Euro if it's a European model as there are differences.
No, i'm on three in the Uk.....sitting in waiting for phone to arrive on my day off as we speak.
This is the code you quoted me earlier and that would seem fine for me
riverboat wrote:No, i'm on three in the Uk.....sitting in waiting for phone to arrive on my day off as we speak.0576350: RM-505_EMEA_EURO_QW1 White
Good luck with the debranding.
I can confirm that this does work:-
just make sure when you use NSS that you have fully exited Nokia PC Suite/Ovi Suite as there seems to be some conflict there. :icon14:
OK new to all this as have always been a sonyericsson user, but have also done the product code change before on a N95 I had a couple of years ago. It seems from what I have read, that Nokia can tell if you have changed the product code, but I have already done this yesterday to see if the update was available but it was obviously pulled or other issues due to the load on Nokias servers. So now to my questions. As I have already changed the product codes, even though now it is back to the original 0585262 VF code, I can only assume I have now voided my warrenty. SO now changing it to the euro 1 0570817 euro 1 black code I know after checking that it is available to update now. So if I do the update how can I get my wap, mms, and so on settings back on my phone to be able to use them. Is there a settings wizard or something like there is on SE phones, to be able to download these items, as all I seem to be able to find is email setup. Has anyone had to take a phone in for repair after changing the product code and been charged as I find it hard to belive that changing the product code due to Nokia being soo slow to release the various versions of software would effect a hardware issue such as the camera lens issue or as some have had the slider issue. Yes if you change the product code and fry the software then you would expect to have to pay for the repair, but not for an issue that is hardware related and so well documented as well.
volvo940se wrote:OK new to all this as have always been a sonyericsson user, but have also done the product code change before on a N95 I had a couple of years ago. It seems from what I have read, that Nokia can tell if you have changed the product code, but I have already done this yesterday to see if the update was available but it was obviously pulled or other issues due to the load on Nokias servers. So now to my questions. As I have already changed the product codes, even though now it is back to the original 0585262 VF code, I can only assume I have now voided my warrenty. SO now changing it to the euro 1 0570817 euro 1 black code I know after checking that it is available to update now. So if I do the update how can I get my wap, mms, and so on settings back on my phone to be able to use them. Is there a settings wizard or something like there is on SE phones, to be able to download these items, as all I seem to be able to find is email setup. Has anyone had to take a phone in for repair after changing the product code and been charged as I find it hard to belive that changing the product code due to Nokia being soo slow to release the various versions of software would effect a hardware issue such as the camera lens issue or as some have had the slider issue. Yes if you change the product code and fry the software then you would expect to have to pay for the repair, but not for an issue that is hardware related and so well documented as well.
All the settings stayed the same for me, seemed as if the 3 settings where hard coded into the phone or taken from sim.
All settings should not be affected,
However there is both a Settings Wizard and Phone setup on v20.
Thanks everyone, so is it safe to go ahead and change the product code to euro 1 and get V20 or better to leave it until Nokia and voda find the time to get together and maybe think about bringing V20 out for us. Also what is this hard reset thing all about? seem to see everyone recomends doing a hard reset after the update, but what will I need to reinstal on the phone after this, what will be lost? I currently have 34 mb of free space on the C drive, what increase will I be likely to get after the update and hard reset if that is needed?
Cheers
Stephen
Hard reset will wipe everything from c:
You can either type in *#7370# and enter the password 12345 or hold down Back space, Space bar, Left shift and the power button untill you see the hands after the phone boots.
See here for the best way IMHO to update your phone (including hard reset code:-
http://mobile.allaboutsymbian.com/news/item/10592_The_Nokia_N97_gets_v20_and_a_n.php
I gained about 10-15MB on C: which allowed me to put a couple of themes/ringtones/widgets on there that I previously had on Mass Memory and which disappeared every time when I connected to PC Suite in Mass Storage.
Even with Ovi Maps 3.03 (7MB), Java Runtime (4MB) plus a couple of themes and 3 widgets (5MB), I still have 34MB free on C:.
So did you gain the extra 10mb after a hard reset or just by updating to V20?
Cheers
Stephen
volvo940se wrote:So did you gain the extra 10mb after a hard reset or just by updating to V20?Cheers
Stephen
My C: drive was at just over 50MB after hard rest and then updating to v20.
Rather than just restoring everything from backup I chose the longer route described here:-
as bitter experience with updates of this magnitude on the N80, N95, have taught me that it's worth the extra effort and prevents a lot of the problems that posters here are getting.
Now have a very fast phone that loads prog's quickly, I've even ditched the Nokia PhotoBrowser beta as the built in Photo's is, IMHO, better and as quick on my phone.
volvo940se wrote:Thanks everyone, so is it safe to go ahead and change the product code to euro 1 and get V20 or better to leave it until Nokia and voda find the time to get together and maybe think about bringing V20 out for us. Also what is this hard reset thing all about? seem to see everyone recomends doing a hard reset after the update, but what will I need to reinstal on the phone after this, what will be lost? I currently have 34 mb of free space on the C drive, what increase will I be likely to get after the update and hard reset if that is needed?Cheers
Stephen
Hi mate, i bricked an N86 the other day.
I changed the product code twice, BUT Pcsuite crashed as well.
I don't know which thing caused the brick or if it was the combination of both.
Please can you post back and let me know how you get on when you upgrade it....
Cheers
Just would like to know where i went wrong.
Backing up my phone now will then do the hard reset and then the update, and see how it goes. Will let you know what happens.
Cheers
Stephen
Evening all. I've just had an absolute breeze in de-branding and updating to V20 by following the instructions here:
Highly recommended.
