How to get through Bounce
9 replies · 3,148 views · Started 12 March 2003
Anyone know how to get through level 9 for bounce 1.8 Version?
Anyone have a clur how to play that stage?
If you do a search, somebody posted a link to a site with all the levels mapped out. Good luck.
*edit*
I got bored.. here u go:
http://www.aikon.ch/div/bounce/losung.html
wow they are the same as 7650/3650 Bounce!
can i ask for a bit of help for end of level 7? i can't get the very last ring which is the small one on top of the area which moves left rapidly.
thanks
jeff.
(EDIT)
I've come to see that there is alot different in the levels.. such as level 7. still stuck though. any help plz?
Ok I probally didn't post this in the right part, but just wondering, I have the bounce version 0.18 where level 9 is not finished! I tried to install version 1.8 but the darn thing askes for my access point on installation............and my phone is crap and doesn't like the internet or any form or gprs, o2 active web etc. Anyone help me out I would be very very grateful!
is there another version of bounce where its more than 11 levels like the standard one? where do i get this new bounce from?
Seremify wrote:wow they are the same as 7650/3650 Bounce!
thanks
jeff.
First go to the exit (it should still be closed). then make a rolling jump to the right and you should just clear the thorn sticking out to the left and land on the pad. Take the ring and exit! 😊
ultra99 wrote:is there another version of bounce where its more than 11 levels like the standard one? where do i get this new bounce from?
u can add more levels to bounce., till level 21. search the forum
tyr pressing 787898 during the game you will hear a beep and go to invinsible mode.
To skip a level 7878993 or 7878991 to go one level back
patrickib wrote:tyr pressing 787898 during the game you will hear a beep and go to invinsible mode.
I've never gotten that to work on series-60, only on series-40
