Hi all,
I have just upgraded the firmware to 300.x. To my surprise, the good old E-Mail-Software has disappeared. Instead, when you enter the Messaging-Button and try to configure the E-Mail-Software, it gives me only the chance to configure an Nokia-Mail-account.
The old integrated E-Mail-solution was far from being nice, but at least it worked very well (for me). I use googlemail basicly because gmail can be configured in a way that it sends mails via my private domain. The same was true in the old mail-Software: you could configure the incoming server (imap.googlemail.com), and the outgoing server (smtp.mydomain.com). This is NOT possible in Nokia Email any more. (Appart from that, I don't want my Emails being stored on yet another server.)
Now:
- Is there any option to manually configure the imap and smtp-servers wich the Nokia Email Client uses?
- If not: can someone recommend a useful client? Handandgo says that profimail is not compatible, and the google mail app does has no option to send via a different smtp-server.
Thank you for your help!
