Is it smart to sell the 7650 and buy the 3650?
Can you record video clips more than 15 seconds? Can you play little movies if you have a larger mmc card?
thanks
greetzzz
thanks
greetzzz
well there is software for both that let you record longer than 17sec. and yes, if you have a big enough mmc card you can put small to large vid clips on your phone and play them.
To help you to decide. Click this ---> http://www.forum.nokia.com/ndsCookieBuilder?fileParamID=2688 or this --> http://nds1.forum.nokia.com/nds/NDS_TVerification_Interface?path=%2Fdownload%2FComparison%5Fof%5FNokia%5F7650%5Fand%5FNokia%5F3650%5Fv1%5F4%2Epdf
download the Comparison of Nokia 7650 and Nokia 3650 Imaging Phones v1.4 and you will see the complete lists on the difference of 3650 with 7650
I'm sure after reading the Comparison of Nokia 7650 and Nokia 3650 Imaging Phones v1.4, You can decide 😉
Can you record video clips more than 15 seconds? Can you play little movies if you have a larger mmc card?thanks
greetzzz
Yes, if you will install Hipcam which will let you change the size.
The Nokia Video Recorder will only allow you to record less than 10 seconds.
