New N97 have i got a non scratching one
2 replies · 1,783 views · Started 28 October 2009
Hiya, well my N97 has finally arrived a day late.
Now before i even turn it on to debrand it, i want to figure out if i am going to have any problems with the lens scratching itself.
Is there any way to tell by looking at the phone itself?
open and close the lens cover for an hour. If you have scratches you have a scratching lens cover. If not then not.
No.
Open the lens cover. If there is a gap between the cover and the lens you should have a non scratching one. If the cover is on the lens it's an old one.
well, there is a miniscule gap, but it seems to press down a bit when you try and slide it..
Appreciate the reply though
