Yesterday when i used the FM Radio (for the first time), i put it on loud speaker to listen. It wasn't very loud so i tried to turn the volume up... it did nothing. It seems as though there is only 2 volume settings, on and off.
Is it only me or is everyone else having the same problem?
Mine has normal volume controls.
Sometimes though the volume control on my phone is unresponsive, so maybe this is the reason you think it doesn't work.
For example, I will press volume up a few times and nothing happens, and then, if I just leave the phone the volume will suddenly increase.
Have you tried this soon after you have booted the phone? When I re-boot the phone is almost unusable for a few minutes.
