Can Apps be loaded on a Memory Stick?
2 replies · 1,544 views · Started 12 March 2003
I have noticed that when I install Apps I have a choice to install on my memory stick.
Has anyone done this? Are there any problems. It would be great if I could... I have extra space on my 64 MB stick.
Thanks for your feedback.
cmjars
you can install apps (or files) on your stick no problem they operate in just the same way as thoseinstalled on the C drive (some may argue a slight loss of speed but it's hardly noticable).
Cheers
Jago
I don't believe that ALL apps will run ok from the memory stick. I installed Safe program from the great swedish software co. and it would only run correctly when installed to the phone's internal memory. Everything else I have installed no probs into memory stick. :-?
regards
Touchstone
