Download free
10 replies · 10,293 views · Started 12 March 2003
Hello all, i'm italian and i don't speak a perfect english... So... Where i can download programs 4 my 3650? I would like to have camera fx and photo editor... Please, help... I can't visit a web site from a pc... Only whit my 3650.. And where i can download video? I'm searching 4 a record player with sounds and video... Please, tell me a site to download this programs 4 free and complete, thanks a lot..
hello to the land of the ferraris and welcome to the 3650 group
the programs you asked for are not for free but you can find free programs on the following websites:
my3650.tk
www.allaboutsymbian.com
www.my-symbian.com
www.the7650.com
hope there any use to you 😃
my genix is a program to change the way your mobile menu looks its an ok program but you have to instll it on the phone memory not memory card 😉 😉
[quote="Anonymous"]my genix is a program to change the way your mobile menu looks its an ok program but you have to instll it on the phone memory not memory card 😉 😉[/quote]
is this application free?
The apps name is Trigenix 😃 and get it from www.trigenix.com
App is free, but some skins cost.
Thanks~
Do u use it? I heard skinning programs were 'harmful'.. and I'm also concerned because I'm using version 2.49 (more unstable than... [insert joke]). Does it replace the OS or run on top?
Thanks again
jeff.
[quote="Seremify"]Do u use it?[/quote]
No, as it takes too much memory and it isnt that good looking.
[quote="Seremify"]I heard skinning programs were 'harmful'.. [/quote]
Thats true of wildpams wildskinz, but trigenix is more stable.
[quote="Seremify"]Does it replace the OS or run on top?[/quote]
It runs on top. And it only replaces the main screen. (in this version)
[quote="JyriK"]The apps name is Trigenix 😃 and get it from www.trigenix.com
App is free, but some skins cost.[/quote]
Thanks 😊
I just downloaded it to give it a try. It tries to connect using a WAP connection to trigenix server but it cannot connect 😞
May I ask why I need to connect it to their server? to download something or ???
Appreciate a response 😊
I think the answer in at the trigenix site... go and check it out.
Might be it wants to load more skins or something.
[quote="JyriK"]I think the answer in at the trigenix site... go and check it out.
Might be it wants to load more skins or something.[/quote]
I guess i dont need to let it connect since i able to download the skins at adressremoved after playing around with the metal skins, I decided to remove trigenix coz its useless for me (maybe not for others)
Thanks...
