On line videos run on E90
4 replies · 6,033 views · Started 31 October 2009
Has anyone found an application where if you are on a web site and it has videos on it, you can click on the video and it will run on the E90. It will bring up the video screen but no video or sound.
Same thing happens on my E62.
Any suggestions please???
Thanks,
Bobby
Check the firmware version of your E90 . Dial *#0000# . When it is version 210.xxx , 300.xxx or 400.xxx then Flashplayer-Lite is build in .
In case the video on the website is a Flash-video it will play in the Web-browser . Just click ON the video about 3 or more times . First to activate it . Second to make it play . Third to open the video in full-screen .
Use options for volume .
This example needs about 5-7 clicks . Because it is on Youtube you also can select the default/standard videoplayer for playing in Real Player :
http://www.allaboutsymbian.com/news/item/10667_Video_titbits_from_SEE_2009.php
😊 Regards jApi NL
Thank you very much. Actually I have 400XXXX as I just a few days ago updated my firmware. I will try your suggestion.
Thanks,
Bobby
Thank you. I just filled in my reply on that link. Yes the old rice and drying it out open worked. Her phone works fine.
Thanks,
Bobby
