I'm still very new at this, so don't shoot the messenger.
The winscard.dll error Running both the key and jaf as administrator may solve your problem, (i'm not sure, but i think you may be able to actually delete the file.
But a couple of pointers. in Nemesis did you follow this very simple guide?
http://nokia.nigelcoldwell.co.uk/firmware.htm
(don't forget to click on phone info before you WRITE the new code)
Or this
http://n97debranding.blogspot.com/
Also Lasikie has written a nice guide
Earlier in this thread http://www.allaboutsymbian.com/forum...9&postcount=24
and this http://www.symbian-freak.com/forum/v...p?f=11&t=35935
Have to do a bit of searching for certain files
Or download them here http://www.megaupload.com/?d=VJ3V1AM8 (Please remove if I ain't allowed to post these.)
I'll try and put it as simple as I can.
1. First get the USB Cable Driver version: 7.1.20.0 (not 100% sure if you need these exact ones but they worked for me.)
2. Plug phone into pc and let windows install the drivers for your phone
3. Then get navifirm and download the required firmware too C:\Program Files\Nokia\Phoenix\Products\RM-505 (you have to create that folder)
4. Next install JAF 1.98.62 (don't install the drivers that comes with this when asked)
5. Download JAF 1.98.64 and copy the ini files from this into your JAF 1.98.62 folder. (Whilst your here if your running Windows 7 make sure to set jaf.exe to run in compatibility vista sp2 mode)
6. Search and download PKEY V5 (V3 if running vista/windows7, and again change compatibility mode)(Some antivirus report this as a virus I chose to ignore and still have a clean system)
7. Run PKEY and click on go, press ok when it asks about box drivers. Jaf should then be loaded for you.
8. Select BB5 tab at the top.
9. Check Manual flash, Dead USB, Factory Set and Normal mode.
10. Uncheck CRT 308
11. Check Use ini and a box full of different phone models will pop up, find your phone highlight it and press ok.
12. You should then see your phone and firmware your going too in the drop down box.
13. Check Change also product code (Just in case )
14. Your now ready to flash, first unplug your phone from pc remove battery and press the power button down with no battery in to remove any left over power.
15. Put your battery in and press flash on JAF
16. Press OK and plug your phone into pc.
17. When Jaf says PRESS POWER ON NOW! do it (Usually happens instantly after pressing ok.
18. The new Firmware will then be installed, just leave it alone untill it beeps and says done twice on JAF
19. Enjoy
Lastly, here is how i did it.
successfully debranded and updated N97
Just a bit of info for new N97 owners like myself.
I took delivery of a brand new N97 yesterday and debranded and updated it.
I'm on Three Uk and decided to order via the internet to be safe as the DSR apply (Distance Selling Rugulations)
Having bricked an N86 the day before i was understandably nervous.
So here is what i did to be extra safe.
Uninstalled Nokia PC Suite, and then ran pc suite cleaner
available from Nokia
http://europe.nokia.com/get-support-...-suite-cleaner
Restarted computer.
Once restarted plugged in phone for it to get the N97 drivers.
Restarted computer.
Then downloaded and installed pc suite.
Restarted computer.
Installed Nemesis.
Restarted computer.
Plugged N97 in and changed product code . (chose a Euro one)
Restarted computer AND phone.
Plugged phone in and started pc suite.
Had to install pc suite support onto phone.
Restarted computer
Ran pc suite selected update phone, and all went okay.
didn't need a hard reset but did one anyway to clean everything up.
Left with a N97 debranded and running V2 software and with 60mb free on C drive.
I know it might seem a long winded way to do it, but having had pc's for years where you always had to restart in between updating programs, i decided to do it that way and be safe.
