Euro 1 V2 uninstall from C: and optimise Memory
3 replies · 4,152 views · Started 31 October 2009
To start with
Boingo
Joikuspot
Qik
Nokia Messaging (what is this anyway - needed for the email widget?)
My Nokia (again, is it needed - what for)
the MFe Folder - what is it
What can/should i uninstall from C: and re-install to E:
Sure those of you that have had this phone fro a while can offer some great tips.
Cheers
I'd uninstall the first 3 if you can, i much prefer nokia messaging over the regular e-mail, plus it's the only one that would work with my ymail.com account.
The Mfe folder is for exchange, i just moved it into a folder called crap within my applications folder which has all the duplicated/unneccesary icons in it..
The shortcut to install Boingo cannot be deleted.
If you have already clicked on it and installed it as a destination, you will need to download and run the Boingo Destination Uninstall from Dave Cozen's website.
You can't get rid of the Boingo icon since it is a protected part of the OS, so do like the previous poster said and move it to a folder that you don't plan on going into.
I call my folder of that stuff "Parked"...meaning it's there and not going anywhere.
