n97 mini questions
2 replies · 2,493 views · Started 31 October 2009
Anyone got an n97 mini? ive got a couple of questions:
1. I dont seem to be able to set default numbers for contacts. When i open the contact and select defaults from the menu it dumps me back to the contacts list??
2. My firmware is 10.0.020 is this the latest for the mini? Everyone seems to talk about v20 for the n97 but i already have kinetic scrolling etc so presumably this is the latest?
I don't own a N97 mini sadly . Normally when you choose a contact , the device doesn't know your next step : call / videocall / Voip / SMS / MMS / eMail / edit / etc / ???
The fastest way to make a regular cell call , select contact > press green call key / select number (in case of multiple no's)
V 20xxx is about the regular N97 .
The mini came from scratch with kenetic scrolling . So I suppose v 10xxx is the first and latest version . (dial *#0000# also for FOTA-updates )
😊 Regards jApi NL
thanks for the info. would still be easier if the defaults thing worked, seems like a bug at the mooh well.....
