Hi all,
Having just updated my phone to v20, im finding that im unable to connect to maps, saying that there is no internet connection.
I've even uninstalled maps3.1 to see if that would solve the problem, still getting the same...im sure its a simple setting that has switched off, could anyone advise please ?
Also, when solved id like to reinstall maps 3.1 - is there a setting where it and the actual maps can be saved to mass storage instead of c:/
Cheers
Matt
Hi all,
I have sorted the maps + found out how to save maps to the memory however ive one quick question on the matter, could someone check in maps on the orange network what there netowrk destination is ??? mines set to wap services is this correct ?
Also, ive downloaded and installed sky remote record on my phone however when I log on I get the following error "failed to connect to network" please check you have selected the correct access point.... any help please ?
Cheers
Matt
Is sky remote now available on the N97?
When I tried to get it a week ago, I got a message saying not compatible with my phone.
I miss this app, as I had it on my N95.
dog-man
How do you get it to save on the E drive please.
dog-man wrote:Is sky remote now available on the N97?When I tried to get it a week ago, I got a message saying not compatible with my phone.
I am running Sky Mobile v1.01 quite happily on my 5800XM and N97.
When you said Remote did you mean Remote Recording? If so it works fine (despite the warning that the app is not compatible during installation).
If you need the installer, PM me with your email addy. 😉
