Hi, i'm trying to get my N86 to use the wifi connection at home.
I want to download shows from iplayer.
I have created a connection to my wifi, i have set it to destination number 1.
In Real i have set it to connect via the wifi access point.
In fact i hae set everything the same as my N97 But it won't connect.
If i delete the 3uk 3g connection then Iplayer works fine and the "download" link appears (only show if you are connected via wifi)
What other settings should i check?
