TipicME pjava for P800 released!
7 replies · 2,532 views · Started 13 March 2003
I'm glad to announce you the new version of TipicME for P800. From the press release:
Following are the new features for TipicME 1.2 Basic:
- improved User Interface
- autoreconnect if the connection is broken
- improved messaging and presence reliability, allowing you and your friend to know if a message was correctly sent/received.
- more stable connection and some bug fixes
In addition, the P800 version, written in Personal Java, feature:
- personalized avatar support (take a picture and set as avatar!)
- notification of new messages even when you are using other
application or with flip-closed
The PRO version of TipicME will be available soon, it will feature:
- possibility to choose the XMPP/Jabber server you want to connect to
- bandwidth usage compression (up to 50%)
- support for location based services
- 128-bit encription of your communication
Go to www.tipicme.com for download.
Gino
Just to say that this is *brilliant*. I tried the new TipicME over GPRS yesterday... loads of conversations for about 0.2 MB - so much cheaper than text messaging 😃
I have to agree.
With MSN and ICQ transports set up, this is a very useful bit of kit.
Bit confused as to why this is a post of 1.2 being released today... Hasnt this been available since the middle of last week? If not I'll have to download it again - great bit of software.
I got that same error when I put my username as:
*******@tipic.com
When I changed the username just to ******* (without the @tipic.com) then it all worked perfectly!
Most likely your password is incorrect...Go to the main site and check your profile... Doublecheck L/P then try again... My only problem now is getting all servers to connect...
how do you know if alo members are connected does it know itself if you enter their screenname? and do you have to write name@aol?
