when i try to open my calander, I am getting "application closed" dialog with "applicationcalander, reason codeagenda model, reason number0". tried removing the INI files with cntrl-shift-I, but to no avail.
Please help...
Please help...
Hello, try to download Task Manager at http//www.psiloc.com/nokia/eng/taskman/index.html and close some applications that may be consuming your communicator memory, or try to open the Internet application that usually closes all resident tasks and then, open the calendar.
Regards
unfortunatly, this doesnt help. I even removed the battery, waited long 30 seconds and rebooted (procedure known for its power in closing applications
still the same result. I am using firmware 3.18, BTW
Just a guess, but unless you have somehow erased some essential file somewhere, perhaps the problem is related to the default Calander file becoming damaged.
Assuming you have got all your data safely syncronised, try deleting the default calander file (it is in the Data folder).
If this was the problem, then I think it will create a blank one to replace it.
If this works, don't sync. your calender, or you will erase all the entries on th PC as well.
The best thing to do then would be to delete the current Calander Sync task and create a new one.
All this is just a possiblity.
Best of Luck.
Zuber
Thanks, that solved it. luckily I had a "recent" backup, or should I say luckily I am not writing much in the calander....
