hi frds,
i have nokia n95 and m just trying to reinstall my current firmware but the software doesnt give any option to reinstall the firmware
version of nokia software updater is 1.8.en....
how to reinstall current firmware of nokia n95.......
type *#0000#
on the keypad and tell us what you get.
can you use PC Suite or Ovi Suite to backup your phone?
Do that BEFORE trying any update.
Hi
I am having a problem with my Nokia N95 - RM -160. Cannot launch messeging and call logs.
How can I sort this problem out?
I tried to install the update using NSU. There is serious problem with my internet connection and cannot update using NSU. Is there a way of downloading the update using Accelerator Plus? Rather than using NSU?
Or can anyone tell me if there is another solution for the messeging/call logs problem other than updating the firmware?
Thanks and regards,
Aparna
