My 5800 can't show RDS from all station. I had checked my pals 5800 and it could show RDS from one station and mine with exactly same station didn't show anything.
I try to connect to wifi first (well y'know I think that will solve the problem😃) and then I turn my radio on but nothing happens.
Can help me with this problem?
[Help] RDS Problem
RDS requires a good signal, and signal is affected by the length and type of headphones attached. Maybe you should try swapping earphone cables with your friend to see if this explains his better rds.
When I use the nokia earphone extension (the cable thing with the remote control) the reception is better.
