Preparing for upgrading new firmware
6 replies · 2,421 views · Started 06 November 2009
Ok, my patience is running out waiting for Vodafone UK branded 0585262 firmware.
I will probably be debranding on Saturday to get the new firmware.
I have seen advice that anyone doing the upgrade should remove as much as possible and format 'c' and mass memory.
Can someone explain exactly what I will need to do to format 'c' and mass memory?
Any other tips gratefully accepted.
I have debranded my N95 before so know what to do there.
dog-man
first goto file manager and backup contacts, bookmarks and cal entries to mem card, then format mass mem from file manager, then goto homescreen, open dialpad and type *#7370# and then put in ur security code (default is 12345) and phone will format c drive and reboot, then change code (id use euro 1 or uk code) then update, once done goto file manager and restore contacts, bookmarks and cal.
Install apps etc, sort settings, goto file manager and backup settings for future use,
job done.
Thanks. :icon14:
***Just padding out this post in case I get moderated for such a short message*** 😮
dog-man
When you say goto file manager, are you referring to the one in Nokia PC suite?
I can't find one on my N97 and I can't see anyway to format in Nokia PC suite.
Must be going senile.
dog-man
Biggzy wrote:first goto file manager and backup contacts, bookmarks and cal entries to mem card, then format mass mem from file manager, then goto homescreen, open dialpad and type *#7370# and then put in ur security code (default is 12345) and phone will format c drive and reboot, then change code (id use euro 1 or uk code) then update, once done goto file manager and restore contacts, bookmarks and cal.
job done.
dog-man wrote:When you say goto file manager, are you referring to the one in Nokia PC suite?
dog-man
File Manager is there on your N97.
I can't tell you where, because i've moved my menu all around to where i like things.
At a guess though for you, i'd try apps folder first.
