realplyer problem
3 replies · 2,655 views · Started 13 March 2003
hi everybody i got a new problem...
when i transfer real player music(rm) i recive it as a message so my question is there a way to transfer it a file??
You could try this:
http://nokia-3650-software.epocware.com/PC_File_Manager.html
Buy it, its really usefull app.
Excellent program, I use it myself and recommend it to anyone 😊
Thou the same can be done in NokiaSuite for 3650 if memory serves me, which is free.
If you do not have it it is downloadable from the nokia website, just head for 3650 then support and you should find it amogst the software pages.
Best 😊
[quote="JyriK"]You could try this:
Buy it, its really usefull app.[/quote]
is it better than the 3650 PC suite?
I easily transfer/convert files and sync PIM using it over bluetooth
*edit*
ok just saw it, guess its more of an explorer kind of prog.. which is handy since PC suite is crippled with that regard
