I can't figure out what to check, other than re-downloading Oper Mini 5 Beta.
I on Three, but phone is switching between Three (my network) and Orange.
I can connect fine to the built in browser, and maps is downloading info fine.
But opera isn't connecting at all. And yes i have held down the red key to ensure that there is no other connection active.
Can you offer any suggestions?
have you tried using direct method instead of proxy? theres a setting in opera for that
i can't find that in the settings.
Opera mini 5 beta
settings - advanced - protocol - set to http
jerm wrote:settings - advanced - protocol - set to http
thanks for that. Seems to have done the trick.
What did changing the settings actually do?
And will i need to change the settings back when i get home?
socket = proxy = connecting probably through a specified port other than 80,443, etc to a back end server that compresses and serves the web pages through to you, hence making them really small
http doesnt do that, it's a direct connection to the web from oMini, just like the web browser
if you're on unlimited data, you can opt to change it back to the original socket style as it proly serves up faster loading times, other than that theres ntg much of a difference on an unlimited data plan
