I changed my code to the Uk black.
Upgraded to v2.0 and have now started to replace all my settings.
I am trying to add my home lan settings, but something strange is happening.
I select settings/connectivity/destinations, but when I do I get a 'system error' message and cannot progress.
Anyone know why?
dog-man
Panic over. The Vulcan death grip fixed it. :tongue:
dog-man
Still having some problems......
I have configured my home wlan and the N97 connects, but I cannot find or perhaps remember where to enter the ip address, subnet mask, dns server etc.
I assign ip's on my network.
Can someone point me in the right direction please?
dog-man
Found it and now working perfectly, but..............................
Since changing the code in NSS, I cannot get NSS to recognise the phone anymore.
I used the Uk unbranded code 0585162.
The phone seems to be working normally and nokia pc suite recognises it.
Should I be worried?
dog-man
dont be woried about nss now, just remove it, its served its duty
But surely it should recognise my phone with the new code?
dog-man
its hapend to a few ppl i know, dnt worry bout it, im sure its not a prob, not sure if its a nss prob or nokia driver problem conflicting with nss, if its a nss prob it will be sorted if the nss team know about it
When I first tried NSS it wouldn't recognise this phone, thats before I even attempted to change code. On a second ocassion, it was fine.
I think, if you fire up NSS immediately after closing down the Nokia Software Suite, that software is still "holding onto" the USB connection. Give it a little more time after you close down the Nokia stuff, and you should find NSS will read it. Thats what happened to me anyway.
Regards
Neil
I think I shut down and rebooted and had the same result.
I have managed to change the product code, so it's not a major problem, but am just curious why NSS won't recognise my phone after the change.
I am going to try another computer.
dog-man
Tried another computer and got the same result.
Looked in task manager to see if anything Nokia related was running.
There was a Nokia server file running, so I shut it down.
Tried again and it worked first time.
So it was a conflict that caused the problem.
Even though I don't have Nokia Pc suite running on startup, this file was active.
This explains why even though I did reboot my other computer, it still wouldn't work.
dog-man
