Me and Doris have never really got on, she's always nagging and going cold on me until today when I tried again and for a brief moment everything was going well.. Thing is I had no connection going over GPRS, WAP or GSM so I was wondering how I was downloading photo's from my webpage so quickly until I realised I had bluetooth still connected and it was running straight over that. Problem is Doris doesn't realise i'm having an affair with my PC so tries to start up a connection over mms (which the only webpage I can view is O2, funny that..) this then confuses Doris as i'm already connected over bluetooth then she breaks down on me, what am I to do it's such a mess :cry:
Basically, anyone know how to tell doris only to use bluetooth and not to try and make a connection?
HI!..
You must set up:
Settings/Connection/
GPRS ... ACCESS POINT and put the name of your PC connection Access Point there..
Then put the pc connection access point on Doris...
that have to work..
cya! 😃
give her the kick she deserves... :agrue:
I gave her a good kick but she refuses to play ball, I tried what you said AEFOX but how do I know what the name of my PC connection Access Point is?
HI!
Create a new access point...
with the default settings..
put only the name... the rest leave like it is...
put a name like "pc" for example..
then put that access point on the GPRS access point
Settings/Connection/GPRS ... Access Point... pc ..
then selecto that access point on the Doris Preference too..
make the bluetooth connection PC-7650 ... and go..
that's all
cya!
Thanks AEFOX, it kinda works but the little G in the corner keeps trying to connect and bluetooth works whilst it trying to connect but when it can't connect to gprs the "select access point" window appears again, I have to click on the PC one and then it tries to connect again so I have a few more second using BT before it cycles around again.
yep!..
i know that.. but always connect by BT...
but don't worry.. just push always the same yes .. yes.. connect again.. yes..
that is like a Doris Sexual Game you know?. 😃
a bugg ..
cya!
aaaah, ok. She's a kinky little minx. 😃
