darnnnnnnn this.....
3 replies · 1,548 views · Started 13 March 2003
ok ppl i traded in my 7650 n got a P800 for a bundle here in india....but i am reallly disappointed with a few things and it is getting on my nerves....
firstly, why on earth is the camera picture quality soooooo bad....i compared with the 7650 pics n there is like helluva difference.....cant believe SE wud mess up so bad with the camera....is there anyway to improve the picture quality.....
secondly, no delivery reports and here in india there is no system of typing in a code before ur msg n then sending it....suckssss....
thirdly, pc suite doesnt work for win 98 or 98se.....mannnn sucks bigtime.....now i haveta find out who has a higher OS n then go n beg them to let me access their comp....
can someone pls help me out on these problems n i have tried the search function so guys pls dont tell me to use the search function....
n is it just a rumour or a fact that firmware upgrade will available to P800 users officially from SE to be downloaded via the net????
lastly sum1 pls key me in on the latest firmware....mine is R1D
thanx mates
later
[quote="futuredoc"]ok ppl i traded in my 7650 n got a P800 for a bundle here in india....but i am reallly disappointed with a few things and it is getting on my nerves....
thanx mates
later[/quote]
1/ Not a lot you can do other than play with the settings (compression quality, brightness etc). It's just very poor.
2/ Nope, no delivery reports. This seems to be an Ericsson thing. Never had an Ericsson phone with 'em. Nothing you can do.
3/ PC Suite is supposed to be in development for W98, but no word on release date.
If all those things were so important to you, it might have been an idea to have a look at the spec BEFORE spending a fortune on the phone?
And yes, it's still just a rumour about the firmware updates for now, and the latest generally available firmware is R1D, though some countries seem to have got hold of R1G.
First of all the camera IS THE BEST mobile phone camera! The quality is a result of missing proper software! The next firmware upgrade will have nightmode that is missing for the moment!
As for the firmware I think you are REALLY confused!
Latest PHONE firmware is R1D
Latest PDA firmware is R1G05
Phone and pda firmwares are 2 tottaly different things!
This mobile phone will be a totaaly different phone after a couple of firmware updates! I suggest you wait a bit more and see what happens!
As for message delivery report it will be also included in the very next firmware update!
[quote="Anonymous"]First of all the camera IS THE BEST mobile phone camera! The quality is a result of missing proper software! The next firmware upgrade will have nightmode that is missing for the moment!
As for message delivery report it will be also included in the very next firmware update![/quote]
Is it possible to download the firmware? How can I check the firmware?
What is the maximum number of contacts? I can not sync my 3,500 contacts from Outlook XP! :roll:
