Guys, I can't get my video off of my phone. I used internal memory to store the video.
Something is wrong! Help! How do I get videos off of my phone, or videos? I can't do either! I can't get them into my computer... do I have to upload them? Blah 😞
Which phone are you using ?
Anyway here is a thread about Saving Memory . These tips can be used for all S60 Nokia phones . And a thread about hard Reset in case you cannot cope the problem otherwise :
--Save Memory (5800) :
http://www.allaboutsymbian.com/forum//forum/thread/84082/
-- Hard Reset 5800
http://www.allaboutsymbian.com/forum//forum/thread/83395/
😊 Regards jApi NL
The hard reset works.
Also, is there a way to ROTATE videos for viewing on my computer? Or must I use a third party program?
ummm all you do is connect your phone to the computer with a usb cable. then you open my computer and go to the folder with your videos. copy and paste to your desktop, and youre done. pretty simple.
I can't find the video... I have no MEMORY CARD in my phone. It's INTERNAL.
