My N95 8GB (RM-320) started to reboot at random intervals. And this afternoon it went to a reboot cycle. I performed a hard reset using four finger salute. Thinking it might be a firmware issue i upgraded the firmware to 31.0.015 (latest). Now when i try to start the camera, it rotates the screen to landscape and then just crashes. I tried other applications which use accelerometer such. Step counter does not crash but does not register any movement at all. I installed cCam to check if camera is okay to find out that camera works fine. Also turning on auto-rotation causes the device to go into infinite reboot loop. So i think the culprit here is the accelerometer. I am hoping the problem is in software and not in hardware.
Has anyone come across such symptoms?
