Fi - na- lleee....
10 replies · 2,691 views · Started 11 November 2009
The v20 software has come to Product Code 0576500, for the thousands in attendance and the millions at home, the v20 is being downloaded right now.
Just thought I'd check on line, entered in the Product Code and V20 came up as the latest version, so quickly grabbed the (Windoze ) laptop off the teenager ( she was not happy ! ) and set about NSU.
Will let you know how it goes , V20.0.27, leaving it do over night, as it's late now and I'm knackered - had a marathon 8 hour , 600 mile , drive home! ( but that's a story for another day )
Well, its downloaded and installed with no problem at all whatsoever. Have also downloaded Maps 3.1, NGage and Ovi Contacts all with no problems.
Have only so far added my contacts, and had a couple of hundred songs on the memory card, no glitches so far. A couple of phone calls , and its not hung for frozen.
Dunno if its too early to say it's working well, need another couple of weeks with it to really test it, then will report back. It was approximately two weeks behind the main v20 release, but felt like a couple of years!
Thanks for putting up with all my rantings.
I'm so glad you've been able to download v20 at last!
It would seem that the delay was caused by certain "tweaks" being added your areas v20. Possibly related to local telecommunications regulations or security (GPS) issues.
I sincerely hope that after all this it meets with your approval. Whilst it's not perfect, by any means, its a blooming site better than V10-12 firmware. :icon14:
C Memory running at around 38.5mb, is this about normal? I have got most of the regular stuff installed onto E drive.
Notty - before i upgraded to v20 i had 41mb on c drive, and after upgrade i still had 41mb, no change at all.
however after i did the 3 finger hard reset (not the 7370) i gained an extra 18mb, and because i had gone to the trouble of this type of reset i decided to install as much as i could on e drive, so my phone is now operating on 56.5mb c drive
The only back up i did via pc suite was contacts, everything else i put on manually (music, videos, photos, apps), it took some time but was worth it in the end 😊
keep going matey xxxx
Must admit, so far the most enjoyable part of using the new software is the keyboard, long presses for the numbers and the symbols, makes typing a lot easier.
The scrollin is good, very quick!
