I have a Nokia 5800 and since the last two firmware updates I have had issues with the camera, it just wont work, when I press the camera button the screen just goes a bit darker and thats it. When I press and hold the menu key I can see the app running but when i select it the screen just goes a bit darker.
The Firmware I running is 31.0.101
Is there a way of installing the old firmware as had a camera with that. Begining to hate this phone and should have stayed with Blackberry :icon13:
5800 Camera not workin
Most of the time these kind of issues disappear , when doing a hard reset . Just be sure to have a backup of all your personal data on PC .
Hard reset deletes all data on C: , but the firmware and files on Massmemory or Memorycard stay intact :
-- Hard Reset N97 + 5800
http://www.allaboutsymbian.com/forum//forum/thread/86049/
-- Hard Reset 5800
http://www.allaboutsymbian.com/forum//forum/thread/83395/
--Save C: Memory 5800 :
http://www.allaboutsymbian.com/forum//forum/thread/84082/
😊 Regards jApi NL
I did a back up and a hard reset and even reinstalled the OS and camera worked twice and not same again.
How do I go back in firmware, is that even possible.
Its been a long time since having a nokia and I can see it will be a long time again.
:icon13:
Getting an iPhone next week. What is Nokia doing. If this is the best they can do then Bye, I wont be back
Good luck with the iphone, vince. You could keep the 5800 for when the iphone gets a flat battery.
