Bitween has released MobileFAX, app that allows you to send and receive faxes from a 7650/3650 phone directly. And you can then print those out using IrDA or BT enabled printer.
From author:
Mobile Fax is a Symbian OS application which extends your Nokia Series 60 mobile phone capabilities to support facsimile communication. Key features: - automatic answering of incoming fax calls; - fax reception with retraining of failed pages; - fax viewer which allows to zoom and rotate image for convenient viewing; - fax composer with capability to insert pictures taken with built-in camera; - fax sending with high quality conversion of images to monochrome and retraining of failed pages; - forwarding of received faxes to another recipient; - sending and forwarding also via Infrared, Bluetooth and E-mail; - sending a page from viewer via MMS preserving zoom factor and rotation angle; - printing via Infrared/Bluetooth with user-defined resolution settings; - easy fax management with Outlook Express-like folder system. * Mobile Fax support fax class 2.
Features
- Receive faxes.
- Forward faxes received to another fax number.
- Create and send a new fax.
- View your fax with the viewer.
- Zoom fax.
- Rotate fax.
- Fit to screen.
- Select the fax number from the contact of your SIM.
- Forward fax via bluetooth to your PC.
- Forward your fax to an E-mail.
- Forward your fax via MMS.
- Incoming message alert of fax received in your message box
for more info visit:
http://www.bitween.com/v2/eng2/mfax.htm
To buy visit:
Handango
Price: $26.00
Trial: yes (will only enable few features like incoming fax and fax viewer.)
Size on phone: 160Kb
JyriK
