Is there a useful / easy to use application or method to see how much RAM is being used / remaining?
TIA
TIA
I've got two different ones installed:
MobiMonster's 'System Status' - available via Dave Cozens Freeware Site. This can also kill running apps which is handy.
and
'Device Info' from Moubail, also available via Dave's freeware site.
Hi Notty,
Check out Daves site, i use "device info" i think it's called
Glad to see the old site still getting used 😉
I am using two different Apps to check RAM , C: , E: ;
-- Jbak TaskMan
http://jbak.ru/jbaktaskman_en.php
-- DrJukka. Y-Tasks download page
http://www.drjukka.com/YTasks.html
JBak Taskman : in settings , you can add a Memory display and also clock/date display . Including seconds . (screenshot)
Y-Tasks : Memory Status shows the variety of Memories . Also you can reserve an amount of memory and Compress RAM in Options . (screenshot)
😊 Regards jApi NL
I've used Handy Taskman by Epocware for the last 3 / 4 years.
it costs $14.95 but money well spent.
http://nokia-n97-software.epocware.com/Handy_Taskman.html
A very close 2nd is the free Jbak TaskMan that jApi NL mentions from Dave's site.
Thanks for all the suggestions, will delve deeper into Dave's ' treasure trove'.
Sounds like an adult movie...
I'll get me coat.
Another one for JBak - if you are on the hardcore user side and want to see/kill processes and threads (whatever this might be). Plus: It's free
Handy Taskman is more simple and easier to use. And has larger icons, which make a better touch experience.
