I have been using this blue tooth headset for long time and just forget how to pair up with my new p800, please help... 😃
HBH 20 headset
Press and hold the Yes and No button for about 10 seconds. This will put the headset in discoverable mode (the led will flash red and green). Discover it with your P800 and pair it using code 0000 (that's four times zero) and there you go.
Could you tell me if your HBH-20 also plays the voice tags when you get called. It never did this when I used it with my T39 but, it does with my P800 (I like it).
thank you, I did it...yes, I can easily make a voice call through the headset and find p800 performs better than t39 which always shows "not match"
It is quite annoying that it is not possible to decide on each call wether you will be using the BlueTooth headset or use the phone itself (Transfer Voice to Phone) as it was on the T68 & T68i, where each time you called then it was first trying the Bluetooth , but you had "grace period" to decide not using the Bluetooth device for the specific call.
