Hi all,
I�m looking fro a decent car cradle for my N97, but must swivel for the landscape view (i guess it could stay in that view now, come to think of it!). Ideally an air vent one, or I could mabe use a cigarette lighter version, depending on length...
Anyone got any suggestions/recommendations?
Brodit do a tilt and swivel cradle. The cradles are specific to the phone make and the car also. They come in 2 pieces, the car mount and the device cradle. They fit in the car without having to be screwed in. Just fit between the panels with a bit of double sided tape, no damage.
Get em from here:
http://www.mountonus.com/?gclid=CMn0wujnl54CFVVu4wodP1RTlw
If you want to use multiple devices on the same holder they do an adapter that lets you slide on different device mounts.
I use it for my N97 and my Viliv S5. It's not advert they're brilliant. I've had them in 3 cars and for 4 different phones. Just change the bits as needed.
I need to back up 8Ball on this one.
If you are not looking for a budget mount and don't mind spending some money to get something that really works then you have to go for a Brodit. I have had them in 3 cards now with 3 different phones and I'm just about to order one for my wifes car as well.
John
Got mine here
http://www.dsldevelopments.com/
Search N97 and then match to whatever car model and how you want to mount it:icon14:
