I have an e75 I don't have a data plan but I have wifi at home work, pretty much most places I go.
Can I have the E75 automatically connect to these wifi spots without asking me to confirm this? (just like windows does) if I put the wifi key in it stores the access point in memory, and will work without asking for the key again but I still have to confirm this point to connect.
If this is done can I also have my push/pull E-mail work like this? automatically check for E-mails if wifi spot is active?
nambi wrote:I have an e75 I don't have a data plan but I have wifi at home work, pretty much most places I go. Can I have the E75 automatically connect to these wifi spots without asking me to confirm this? (just like windows does) if I put the wifi key in it stores the access point in memory, and will work without asking for the key again but I still have to confirm this point to connect.
Select the default access point for each of the programs that are asking you to confirm the connection.
You could use the freeware Smart Connect . This lets you cluster several accesspoints just to one SC accesspoint :
http://www.birdstep.com/Products/Birdstep/SmartConnect/
😊 Regards jApi NL
