can someone cue me in as to wot the yellow thingy on the back of the phone is next to the camera???....
n second thing is why on earth is the ring volume so low....is there anyway to increase the ringing volume....i have already turned it on to maximum n have also set it on to ascending pattern which does make it a li'l better.....but as such is there another way....
thanx mates
later
The "yellow thingy" is the speaker.
I actually find that with the MIDIs I use, I actually have to turn the volume DOWN from the highest setting, otherwise I get distortion. Perhaps it might be an idea to increase the volume of your ringtones in an external program?
i think the yellow thing is tha antenna
the ring tone topic was already in this forum.
i dont remember when,
do a search
BM
The yellow thingy isnt the speaker
its for an external aerial
BS again
Further to what Guest said, the yellow thingy is for external anntenae like if you had a car kit the phone would sit in the cradle and use the car antennae.
Nokia phones generally have a rubber plug that erm plugs the hole until you want to use it.
[quote="Durzel"]The "yellow thingy" is the speaker.
I actually find that with the MIDIs I use, I actually have to turn the volume DOWN from the highest setting, otherwise I get distortion. Perhaps it might be an idea to increase the volume of your ringtones in an external program?[/quote]
Doh!!! :roll:
The "yellow" or actually more like "golden thingy" on the back is a connector for an external antena.
[quote="bTk"]Further to what Guest said, the yellow thingy is for external anntenae like if you had a car kit the phone would sit in the cradle and use the car antennae.
Nokia phones generally have a rubber plug that erm plugs the hole until you want to use it.[/quote]
Plugs the hole... har har... 😃
Hey futuredoc, do you have a manual for your phone? I look to these forums for interest and learning. If you need to know the physical aspects of any device it's pretty standard to find a Parts Diagram' at the front of the manual.
