i put my phone on silent earlier. now i have switched back to general and the keylock no longer makes the phone vibrate.
Screenlock slider no longer vibrates
Maybe switch the phone off and on again?
When I was running v10 I found that I had vibration issues related to the the battery... ie. when the battery was on one or two bars the haptic feedback was not vibratin consistently.
Not sure if this may be a cause for your vibration problem or not.
Have to say that with v12 the vibration issues for my phone seem to have been rectified though.
riverboat wrote:i put my phone on silent earlier. now i have switched back to general and the keylock no longer makes the phone vibrate.
Have you tried checking the settings for the General Profile , make sure the vibrate function is ON, otherwise it won�t vibrate.
got it working eventually, swapping from different profiles and turning it on an off a few times.
