Is chinese E66 different from the rest?
3 replies · 7,055 views · Started 22 November 2009
Hi
I just bought Nokia E66 from China. I tried to update the software to scandinavian version using NSS and NSU, but couldn't do it.
NSU tells me that my phone is E66 RM-494. All European E66's seem to be RM-343. What is the difference between these and is there any way to chance the phone from chinese to scandinavian language pack?. If not, then I guess I'm fucked.
Thanks in advance
The Chinese version has slightly different hardware; no 3G, no Wi-Fi.
I don't think you can install Scandinavian E66 firmware on it, as it is for slightly different hardware.
Thanks for information. I tried to have the shop refund the phone today, but no success. Well, it was my mistake anyway. I quess they only refund the phone, if I change it for more expensive one. Can someone tell me, if any of the following phones are the same version in China and Europe?
E75
N85
N86
Hello... i`ve just got my hands on a Nokia E-66 rm-343 although under the battery it says rm 314... it`s not a double sim replica but has no wi fi and no 3g.. and alsow alot of other functions and menu options are missing... i understand that wi fi and 3g are hardware related but about the rest do you think i could do something? And yea, the nokia pc suite and nokia updater wont find my device (the phone) ... is there something i could do? Thanks
