E90 Full screen applications
1 replies · 5,575 views · Started 23 November 2009
Does anyone know of a site or any applications that support the E90 internal screen's full width capacity? In other words, E90 specific applications.
Even if the apps just put the extra window to the side of the standard s60 window (like the File Manager does), that would be an improvement to the legacy s60 phone apps that are made for a traditional phone.
It seems my internal screen is underutilized for applications (except web browsing)
Thanks.
Practically all S60 v 3 applications render on the complete inner screen . Also themes normally no problems . Only one app "Ogg Play" renders half screen and has a skin issue , while the third party browser "Skyfire" goes half way on inner screen and freezing , works surprisingly on the outer screen .
There is two apps , I use that devide the screen , like in Calendar , Contacts , Messaging , etc.
1) JBakTaskman : http://jbak.ru/jbaktaskman_en.php
2) Griffon2 , from the Russian part of the same Website
😊 Regards jApi NL
