Hi
Does anyone know of any reliable N97 Themes and where they can be found - for free 😃
Have tried a few in the past and they have generally proved 'buggy' to say the least
thanks :icon14:
Hi
thanks :icon14:
I use this Maemo theme with no issues.
i use tehk's S60 Hero theme for dayimte, and PiZero's DarkStar for night time
jerm wrote:i use tehk's S60 Hero theme for dayimte, and PiZero's DarkStar for night time
You change theme every day? Very organised 😊
BanziBarn wrote:You change theme every day? Very organised 😊
Presumably, there's an app for that 😉
*chortle*
Thanks for your suggestions!!
i found one i like now
Themes...the darker side of the N97!
When you install Shazam, it adds a very dark ShazamiDTheme. Problem is, like most themes, they didn't test it all the way through and in some places you have dark menu text on a dark background with very little contrast difference.
Worst yet, the way this theme is added, you can't uninstall it even if you uninstall Shazam (which by-the-way is a *VERY* cool must-have app!).
Also themes seem to install only on the already-way-too-small C: drive.
yup, i use smartphoneware best profiles, awesome piece of software, that is
rdcinhou wrote:Themes...the darker side of the N97!When you install Shazam, it adds a very dark ShazamiDTheme. Problem is, like most themes, they didn't test it all the way through and in some places you have dark menu text on a dark background with very little contrast difference.
I really like this theme but you're right, not tested enough and you can't see your calenda properly (from memory). Shame.
After a lot of looking about i found Sun by NCA (search this for places to download)
I got mine from here
http://thenokian97.com/nokia-n97-theme-review-sun-by-nca/
Which has the full version with custom icons or the STD version = standard nokia icons
I really liked this theme but it would'nt install (from anywhere) as there was a certificate error so i did this - from my experince installing Key lock clock from Dr Jukka
(http://www.drjukka.com/KeyLockClock.html)
So as suggested by Dr Jukka i thought i would try and get the sis file signed by simbian signed (https://www.symbiansigned.com/app/page/public/openSignedOnline.do) and try and install it that way.
Had some problems when i tried to install straight after downloading the signed sis file (error along the lines of certificate out of date or device date wrong) but tried again an hour or 2 later and it began to install (i'm guessing that the clock on the server that signs the files is set to a different time and time stamps when the sis becomes valid to use).
It did warn me when installing that this was incompatable with my phone but i took my life in my own hands and ignored it!
Long story short it looks great and i have found no problems of lag, hang ups or general problems.
:icon4: If you do decide to do as i have then be aware that you do it at your own risk!!!!! Just because it worked for me does not mean it will work for you.
For information phone is the N97 with V20 firmware
Thanks for your suggestions everyone - if anyone does install this one let me know how you got on! :call2:
4 themes from Ueli Dauwalder :
http://www.pdanet.ch/S60v5_Themes.html
😊 Regards jApi NL
