Problem with Bemused!
0 replies · 1,533 views · Started 14 March 2003
I am using Bemused to contole my Winamp via Bluetooth.
It only works when I unselect COM4 in the mRouter program which is used by PC Suite to connect to the phone.
Other COM ports do not work.
This is what Ashley, the programmer of Bemused, told me:
Your Bluetooth software on the PC may allow you to add more "virtual serial
ports". If you add another Bluetooth serial port, then Bemused can use this
port and will not conflict with PC Suite.
Thanks,
Ashley.
How can I do that.
