5800 hangs while upgrading
3 replies · 2,966 views · Started 26 November 2009
Hi everyone,
i hope i'm not reapeating any newb question, but i did search the forum for half a day without any results.
My problem. i bought a Nokia XM 5800 off from a friend. its in very good condition, but i was told i require the latest firmware for the best performance.
The phone's current firmware is 10.0.010, it's old, i know. so i proceed to download the latest Nokia Software updater. From the NSU, the latest firmware available to me is the 21.0.025.
i back up all the data on the phone, then i plug in the USB cable. i selected PC Suite. The NSU detects my phone. and i proceed to click update.
Problem:
the phone turns itself off and on by itself, then the NSU detects my phone off and ask me to reconnect. this happens 2 maybe 3 times, then the phone turns on like normal and enters PC suite mode, while the NSU just hangs there. no response. i risk it by unplugging the USB. the NSU hung, no warning, nothing.
But my phone is still running fine. no errors or sudden restarts. but my firmware is still 10.0.010. is this common? is there a way i can troubleshoot? i'm ok with tech jargons, but as long as i dont proceed to programming languages i'm ok.
hope someone can help.
Did you try rebooting the computer? Sometimes, rarely, something getsmofed and when I connect my 5800 to the PC via USB, it causes the phone to hard boot after telling it to connect via PCSuite. Usually, rebooting the computer will cure this.
That said, this only happens to me right away, not after a period of being connected, so I'm not sure this is really your problem.
i've tried restarting the PC.i've tried changing USB ports. i've tried fully charging the phone for the update.
the firmware upgrade is driving me nut...
There are similar issues with the latest N97 firmware-update . See the N97 Sub-Forum . An isue with Vista : only works under administrators rights . Another with PC Suite : 1) Get the newest version . 2) Use OVI Suite instead of PC Suite .
😊 Regards jApi NL
