Okay i get a "No gateway reply" and i checked the post your linked . Here is what i did and the output:
(In both of cases wlan has no security)
Scenario 1:
I make a new WLAN on my laptop, give it ip of 172.30.20.10 and enable connection sharing so any devices connecting via wlan to my laptop should have access to internet as well.
I connect my 5530 with 172.30.20.11 ip and opendns, run tcpdump on my machine and try browsing on my nokia 5530
# tcpdump -vvvi eth1 | grep "172."
tcpdump: listening on eth1, link-type EN10MB (Ethernet), capture size 96 bytes
blade.local.mdns > 224.0.0.251.mdns: [udp sum ok] 0 PTR (QM)? 10.20.30.172.in-addr.arpa. (43)
blade.local.mdns > 224.0.0.251.mdns: 0*- [0q] 1/0/0 10.20.30.172.in-addr.arpa. (62)
10:24:36.958298 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 172.30.20.11 tell 0.0.0.0, length 28
blade.local.mdns > 224.0.0.251.mdns: [udp sum ok] 0 PTR (QM)? 11.20.30.172.in-addr.arpa. (43)
10:24:41.965447 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has blade.local tell 172.30.20.11, length 28
172.30.20.11.47483 > vnsc-pri.sys.gtei.net.domain: [udp sum ok] 39507+ A? fb.link.nokia.com. (35)
172.30.20.11.47483 > vnsc-bak.sys.gtei.net.domain: [udp sum ok] 39246+ A? fb.link.nokia.com. (35)
172.30.20.11.47483 > vnsc-pri.sys.gtei.net.domain: [udp sum ok] 39246+ A? fb.link.nokia.com. (35)
172.30.20.11.47483 > vnsc-pri.sys.gtei.net.domain: [udp sum ok] 29030+ AAAA? fb.link.nokia.com. (35)
10:25:05.022901 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has blade.local tell 172.30.20.11, length 28
172.30.20.11.43300 > blade.local.www: Flags [S], cksum 0x82cc (correct), seq 470311782, win 64240, options [mss 1460,nop,nop,TS val 3157217567 ecr 0,nop,wscale 0,nop,nop,sackOK], length 0
10:26:37.366328 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 172.30.20.11 tell blade.local, length 28
10:26:37.368911 ARP, Ethernet (len 6), IPv4 (len 4), Reply 172.30.20.11 is-at 18:86:ac:df:2d:14 (oui Unknown), length 28
blade.local.www > 172.30.20.11.43300: Flags [S.], cksum 0x12b6 (correct), seq 2531641440, ack 470311783, win 5792, options [mss 1460,sackOK,TS val 132880 ecr 3157217567,nop,wscale 4], length 0
172.30.20.11.43300 > blade.local.www: Flags [.], cksum 0x267e (correct), seq 1, ack 1, win 64240, options [nop,nop,TS val 3157231567 ecr 132880], length 0
172.30.20.11.43300 > blade.local.www: Flags [P.], seq 1:984, ack 1, win 64240, options [nop,nop,TS val 3157235567 ecr 132880], length 983
blade.local.www > 172.30.20.11.43300: Flags [.], cksum 0x0c11 (correct), seq 1, ack 984, win 485, options [nop,nop,TS val 132882 ecr 3157235567], length 0
blade.local.www > 172.30.20.11.43300: Flags [P.], seq 1:393, ack 984, win 485, options [nop,nop,TS val 132882 ecr 3157235567], length 392
Result:
"No gateway response"
Scenario 2:
I do the same, except that this time i assign:
192.168.1.111 as my 5530 ip, 192.168.1.1 as gateway (which is one of my non-wireless routers) and set dns. this time:
10:28:37.021561 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:28:37.154929 IP (tos 0x0, ttl 255, id 0, offset 0, flags [DF], proto UDP (17), length 70)
blade.local.mdns > 224.0.0.251.mdns: [udp sum ok] 0 PTR (QM)? 1.1.168.192.in-addr.arpa. (42)
10:28:38.022312 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:28:38.155552 IP (tos 0x0, ttl 255, id 0, offset 0, flags [DF], proto UDP (17), length 70)
10:28:39.022856 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:28:40.157377 IP (tos 0x0, ttl 255, id 0, offset 0, flags [DF], proto UDP (17), length 70)
10:28:42.025638 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:28:42.187761 IP (tos 0x0, ttl 255, id 0, offset 0, flags [DF], proto UDP (17), length 72)
blade.local.mdns > 224.0.0.251.mdns: [udp sum ok] 0 PTR (QM)? 111.1.168.192.in-addr.arpa. (44)
10:28:43.025694 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:28:43.189324 IP (tos 0x0, ttl 255, id 0, offset 0, flags [DF], proto UDP (17), length 72)
10:28:44.026834 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:28:45.190224 IP (tos 0x0, ttl 255, id 0, offset 0, flags [DF], proto UDP (17), length 72)
10:28:47.030832 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:28:47.221858 IP (tos 0x0, ttl 255, id 0, offset 0, flags [DF], proto UDP (17), length 70)
blade.local.mdns > 224.0.0.251.mdns: [udp sum ok] 0 PTR (QM)? 251.0.0.224.in-addr.arpa. (42)
10:28:48.031432 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:28:48.223465 IP (tos 0x0, ttl 255, id 0, offset 0, flags [DF], proto UDP (17), length 70)
10:28:49.032834 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:28:50.224872 IP (tos 0x0, ttl 255, id 0, offset 0, flags [DF], proto UDP (17), length 70)
10:28:52.036487 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:28:52.512245 IP (tos 0x0, ttl 255, id 0, offset 0, flags [DF], proto UDP (17), length 71)
10:28:52.512456 IP (tos 0x0, ttl 255, id 0, offset 0, flags [DF], proto UDP (17), length 90)
10:28:53.036875 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:28:54.037935 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:28:57.043309 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:28:58.059274 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:28:59.059573 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:29:07.067142 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:29:08.067681 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:29:09.068438 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:29:12.069552 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:29:13.069211 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
10:29:14.069775 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has 192.168.1.1 tell 192.168.1.111, length 28
Result:
