Hey there
i downloaded a movie from my laptop to e90 through USB cable
but i am not abe to find the file on my phone,,
however when i connect my ph to laptop it does shows up,,,
and also many of my pictures from old ph's memory card are not displayed in this new ph's (e90) memory card (i m using same memory card for both phs)
thanks
CAN SOME1 PLZ HELP ME OUT WITH THIS
Help e90
have you used some movie converter?
OR, use nokia PC suite and place the movie in a folder on internal memory or memory card where you can find it.
then use nokia file manager to locate the file or realplayer on the ohone side to play it
hi all,can someone help me,i need to unlock Nokia 2630 orange v 06.82 rm-298 imei:353192038275895...i m in Sweden right now end i use Comviq gsm...
thnk u
Get the unlock code straight from Orange . It is the safest and easiest way .
😊 Regards jApi NL
Irrique09 wrote:hi all,can someone help me,i need to unlock Nokia 2630 orange v 06.82 rm-298 imei:353192038275895...i m in Sweden right now end i use Comviq gsm...
thnk u
Why post such a badly formulated question in a thread about the E90...
If you a. can't be bothered to write a proper question (even if English is not your first language, a bit of punctuation would go a long way) and b. can't be bothered to find a proper thread to pose the question in, you're unlikely to get much help....
