FileExplorer 1.08 beta
11 replies · 3,307 views · Started 14 March 2003
Finally, I have decided to post the beta version of FExplorer 1.08 on 'allaboutsymbian'; this beta is only available in english and expired on march 31st; if you want to return to the previous version 1.07, please download it from www.gosymbian.com
to try the editor, for example, go to c:\system\shareddata, highlight an '.ini' file, go to file-edit to see the content.
any comments, remarks, ... are welcomed
thanks for any cooperation,
Domi.
what's new :
* a 'settings menu' has been added that allows to configure
FExlp. (the settings are saved); you can set up the color
in list, the display of the full path in full screen mode
the full screen mode.
* a confirmation dialog is showed before quitting the pgm
* the restart function has a confirmation message
* it's possible to edit the text files (like ini...)
* the size of the files are displayed on each line and the
font is smaller to display more character.
works very good..
the fexplorer is geting better and better and better..
thanx for the great work domi
:lilangel:
[quote="Domi"]to try the editor, for example, go to c:\system\shareddata, highlight an '.ini' file, go to file-edit to see the content.[/quote]
WARNING TO EVERYBODY
Do not touch those shareddata ini-files!! If you don't know what you are doing (and most of you really don't!), you may end up with a non-bootable phone.
Hello
Is there any plan for the following functions in feature version? or these functions already exist? (Obviously I havent install FExplorer.. I'll be reading the info at the official page.. just want to ask FExplorer users and Domi about the functions mentioned below)
Copy a file to Clipboard or Inbox
Mark/unmark (useful if copying/cutting more than 1 file)
Set Operator Logo (this will be cool)
Create New Text Document
Create path as shortcut or add to favorites
Enable/Disable Infrared
Sort the files by date, name, extension or size
Control Volume/Repeat on/off (not very important)
Auto Keyguard
KeyLock (for 7650 users)
Clean Temp Files
If yes.... No doubt....FExplorer will beat SeleQ, eFileman and HandyFile 😉
First Ive forgotten my password 😞 sort that at home..
Just reset the 7650 and lost my beta file.
Domi's removed the link and the normal version wont download anymore 😞
can someone email me it please - beta if possible?
[email protected]....
Ah and my views for future use - zip functionality - I think this is the weakest bit on my phone at the mo, the ability to just copy a file into a zip file and store it on the phone - I know there is zipman bit it seems more interested in sending and receiving emails not dealing with them on the phone!
Tony (Stormuk)
[quote="Anonymous"]First Ive forgotten my password 😞 sort that at home..
Tony (Stormuk)[/quote]
Actually, the link is still there, guests just can't see attachments-
Register.
Makkara - I did try and say I wasnt a guest but didnt have my forum login password!
Speed of works internet made it a nightmare to resolve - anyhow in now!
Was a concern that I couldnt download 1.7 though that could be due to works poor internet speed so Ill check now!
Tony
HI!...
DOMI!!! nice 1.08 Beta... really nice...
BUT!... time is UP 😮 ... Beta not work anymore :cry:
So... when you will realease the FINAL VERSION of this fantastic app FE 1.08? 😉
Thanks!
Cya! 😃
