Has anybody tried using the P800 with windows NT4 using a serial cable yet?
The software says it only supports Win 2000, Me and XP and I can see this logic as they are the only MS based OS's that support USB (Apart from 98 as well).
My work PC runs WinNT4 so USB is not possible for a connection. I just want to sync Lotus Notes with my P800, not bothered about transferring files (I use my homw XP machine for doing that).
Anybody got any view on if it is possible to set this up to work with WinNT4 using a serial cable, which I have a T68i cable (I gather they are the same as the P800 connection).
Cheers
Lee
