Calendar and clock alarm not vibrating
1 replies · 6,107 views · Started 28 November 2009
hi everyone,
i cant find how to get it to vibrate for clock and calendar alarms. Vibrating alert is ON in all my Profiles, but this only seems to make a difference to calls.
If there isnt a menu for it can i download an app or fix for it?
Also is there a fix for using the Shortcuts Bar but not showing my calender list on the front page? thks for any help
i fixed the calendar problem as i had it on the only tone tht doesnt use the vibrate. lol
But if anyone knows how to remove the list of calendar events while still keep using Shortcuts tht would help alot
